95 accord oil light+overheating
Old Sep 8, 2012 | 09:59 AM
MikeJT1's Avatar
Default 95 accord oil light+overheating
So i replaced my fan switch and my fans are working properly now. Replaced the thermostat, bled the system and flushed the radiator. So at least one of the previous overheating problems has now been fixed. But now when i'm stopped after driving for 15-20mins the temp guage slowwly rises and the oil light begins to flicker -as the guage goes higher the light becomes brighter. When i accelerate the guage quickly comes back down.
Now hopefully this can help to diagnose the problem...
When i got home yesterday after a test drive the car was starting to overheat so while in park, i reved the engine(even if only 1000rpm) and the oil light turned off and guage came back down fairly quickly!
I was happy when i discovered this because i figured it would be much easier to find the fix! Hopefully this IS the case. Any help will be much appreciated!
Old Sep 8, 2012 | 10:18 AM
Are you sure the cooling fans are running when car is stopped and begins to overheat? If not, faulty thermoswitch A may be the problem, not closing at preset temp (199F).
Check for additional air in the system.
If nothing, check for bubbles entering cooling system w/ radiator cap off and cold engine running. Bubbles would indicate head gasket failure.
Oil light could be a failing oil pressure switch. It's probably cheapest to simply replace and see if problem is resolved. If not a gauge oil pressure check is necessary to confirm low oil pressure.
Old Sep 8, 2012 | 10:36 AM
MikeJT1's Avatar
hmm ok il try that. thanks
Old Sep 8, 2012 | 08:43 PM
UhOh's Avatar
Welcome to the forum.
Sounds like you're low on oil.
Use the dipstick to check the amount of oil in the motor.
No insult intended
sullius_iby1n
Apr 14, 2015 04:04 AM
Hondahonda
Aug 22, 2012 08:14 PM
JWW512
Dec 24, 2010 04:59 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
