95 Accord Overheating- ive chged evrything!
Old Jul 21, 2014 | 06:03 PM
  #31
If the "timing was off by 6 degrees" then you should make sure the camshaft timing is OK.
An error in camshaft timing cannot be corrected by adjusting the spark timing.
Old Jul 21, 2014 | 06:04 PM
  #32
Pull the plugs, use the crank bolt and put the engine at TDC #1. Pull the upper cover for the TB - you have to lift the VC....check the cam gear marks to be sure they are lined up. You can cover a bit of a mechanical timing with the dist but if it is off by too much, using the dist is not going to get the car "right.
Since you have the plugs out, inspect them and it they have any signs of wear - replace with a set of NGK's (maybe ~$3 each?).
Also be sure you "jump" the service the service connector when adjusting the timing by the dist.
Old Jul 22, 2014 | 01:19 PM
  #33
chrisrodrick's Avatar
Yeah, It's gonna have to be redone, off timing, possible compression issues due to off timing. Thank you Jim!
Old Jul 22, 2014 | 01:22 PM
  #34
Mornin and Ooraah!! Thank you brother and fellow defender.
blumule
Feb 25, 2013 07:23 PM
Jul 21, 2012 09:26 AM
xboxvidiot
Oct 18, 2009 11:23 PM
erikhaha
Nov 20, 2005 02:48 AM
