95 Accord Running Sluggish
Old Jul 18, 2011 | 09:50 PM
Tek310's Avatar
have you cleaned your egr passages, iacv, fitv?
done a tune up? changed fuel filter? dizzy cap and rotor?
your tech will likely opt to replace the items instead of cleaning them.. which will cost hundreds of dollars..
if they do, i can clean all said items for pretty cheap compared to what they are probably going to charge.
Old Jul 18, 2011 | 10:01 PM
CarIdiot's Avatar
Well, the tech who I talked to, as I mentioned earlier, said he couldn't really get a look at the car today, but would tomorrow. When I described to him on the phone what I felt, he said it sounded to him like a dirty catalytic converter and it may need to be cleaned of carbon.
I searched the headwind symptom and that is apparently very common with catalytic converter problems. The only problem is that exhaust appears to also be a symptom and I don't have any exhaust shooting out of the tail pipe that I know of.
Doing research (Being the car idiot that I am and not understanding things) I found that clogged catalytic converters can be caused by fouled spark plugs or a burned exhaust valve. Considering that I have the symptoms of a bad catalytic converter, minus the exhaust at this point, would it be fair to assume that I'm feeling the early signs of a bad converter and thus it means I have a spark plug or exhaust valve issue?
Thanks, guys!
Old Jul 18, 2011 | 10:19 PM
Tek310's Avatar
it could be a clogged cat. your car certainly has the miles on it lol.
do you smell a nasty sulfur smell when you rev the engine?
Old Jul 19, 2011 | 09:55 AM
CarIdiot's Avatar
Nope. I don't smell anything.
Old Jul 19, 2011 | 08:59 PM
Tune up...clean the egr ports.....if the issue is still there. Then lets get into further testing....
sailaja_giri
May 24, 2008 05:27 AM
dsmulla
Mar 5, 2008 09:00 PM
tony11
Jun 5, 2007 03:31 PM
Jessab
Mar 24, 2007 06:51 PM
DawgatAuburn
Feb 21, 2007 01:47 AM
