95 Accord window problem
Old Feb 24, 2008 | 07:44 PM
dk1
Default 95 Accord window problem
Hi, I have a 95 Accord EX(194k) with a window problem. The driver's side window has a very hard time going up. You have to assist the window with your hand for it to close.We disassembled the door, and removed the window, and the motor works fine. Also, if the rubber windowchannel is lubed up, it will work perfectly.
How do I check to see if the motor is going, or is this a problem with the window binding in the channel?
Thank You!
David
Old Feb 25, 2008 | 10:58 AM
smaglik's Avatar
Default RE: 95 Accord window problem
i think you fixed it by lubing the channel...
Old Feb 25, 2008 | 04:18 PM
dk1
Yes, it works fine when its lubricated, but after a day or so, its back to normal.
Old Feb 27, 2008 | 12:43 AM
gimmieshelter31's Avatar
What did you use as a lube? I had this problem and used silicone spray lube as suggested on this site and it has worked great for the last month.
Michael Bomes
Sep 9, 2012 03:12 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
