96 Accord bleeding oil like crazy
Old Apr 2, 2012 | 09:30 AM
  #41
noiseordinance's Avatar
Hey guys, just rounding up all the necessary parts for the install. I'm hoping maybe someone can double-check the gear that I have so that I'm properly prepared. Here's a run-down of the parts I'm installing and the tools that I have, or will be purchasing:
Replacement items:
Timing belt, balance shaft belt, timing belt tensioner, balance shaft belt tensioner, timing belt tensioner spring, balance shaft belt tensioner spring, water pump w/ gasket, camshaft seal, crankshaft seal, balance shaft seal, drive belts, balance shaft seal retainer kit
Tools:
18" 1/2-inch drive breaker bar
25" 1/2-inch drive breaker bar
24" 1/2-inch drive extension
4-5" extension pipe
A piece of wood to hold the engine on a jack
19mm 1/2-inch drive deep impact socket
Honda pulley bolt tool
Two floor jacks, two jack stands
Standard socket set and tools
Grey gasket sealant
Antifreeze and oil
Timing light (if needed)
Thanks again for all the help. You folks sure are kind!
Old Apr 3, 2012 | 09:43 AM
  #42
No thoughts? I'm about to order a significant portion of this stuff today and could definitely use a little feedback.
Old Apr 3, 2012 | 09:52 AM
  #43
LS-300's Avatar
Looks like you have it all covered. I think the worst part of that job was getting the balancer bolt off. Took mine to a buddy that used a 3/4" inpact running 190 psi. With that the bolt came right off.
Old Apr 3, 2012 | 11:30 AM
  #44
Thanks much for checking my parts list, LS-300, and also, thanks for posting the great photos earlier in this thread. Super helpful. You mentioned the balance bolt difficulty. PAHonda mentioned earlier that there are pointers on removing this thing. Is this at all like the crank pulley bolt where wrenching on it causes it to spin and it needs to be held in place?
Anyways... ordering stuff now, kinda excited. Also going to purchase the Eric the Car Guy video as directed earlier. I watched the out-of-engine timing belt swap and that was plenty helpful, so now I'd like to see it done on a car with engine.
Old Apr 3, 2012 | 01:03 PM
  #45
The harmonic balancer and crank pulley are the same thing, so the harmonic balancer bolt is the same as the crank pulley bolt.
I didn't see something obviously missing from your list. Take a picture of your setup to remove the harmonic balancer bolt and post it on here (or any other pictures that you feel like taking).
Remember to start off by removing the plastic cover(s) for the harmonic balancer bolt, then remove the bolt before doing anything else.
Old Apr 3, 2012 | 01:09 PM
  #46
LS-300's Avatar
+1, good luck
Old Apr 3, 2012 | 02:07 PM
  #47
Hehe, well my face is red. Thanks guys, didn't realize they were the same thing. I guess what I'm curious about is the kit I'm purchasing contains a "camshaft seal, crankshaft seal, and balance shaft seal". These are essentially located behind three different pulleys that hold the timing belt right?
Edit: Perhaps the difference will be apparent once I watch the Eric the Car Guy video a few times.
Old Apr 3, 2012 | 03:32 PM
  #48
brayner's Avatar
it will be obvious once the covers are off.
The crank bolt can be very hard to loosen
Old Apr 4, 2012 | 01:44 PM
  #49
desertmike1's Avatar
Your list of tools look pretty decent..
Start spraying the crank bolt with some kind of penatrating oil in advance.
Do you have access to torque wrench's for the reassembly, or just planning on winging it...
This will be alot of fun for you, take picures along the way.
Old Apr 5, 2012 | 05:18 PM
  #50
I'm a little late but some things I would think about. The drive belts have to come off (ac, ps, ect) so if they have miles on them.....why not. EDIT: I see these on the list now that I read....sorry.
Next, easier to spin the motor to TDC and that when the plugs are out, so same thing-if they have miles on them
jfriedel88
Jun 19, 2009 06:44 PM
nmikmik
Dec 1, 2007 11:14 AM
SandMan
Sep 22, 2007 12:33 AM
BlueByYou
Oct 8, 2006 01:43 AM
LinX
Feb 27, 2006 04:01 AM
