96 Accord Starting Problem
Old Jan 21, 2012 | 09:37 AM
dpalmieri's Avatar
Default 96 Accord Starting Problem
Occasionally our 96 Honda Accord won't start. Nothing happens when the key is turned. You can usually rapidly turn the key until the car starts, although sometimes it won't start at all. This does NOT happen after the car has sat overnight or all day it work, it happens after being off short periods of time, such as after a trip to the store. This happens in any kind of weather. It has happened for several months and it seems to be getting worse. We'd like to get it fixed because we are afraid of getting stranded somewhere. Has anyone had this issue with the same conditions/symptoms or does anyone know what it may be?
Old Jan 21, 2012 | 09:54 AM
I'd start with having the battery and alt tested (most places will do this for free). Check/clean/tighten the battery cables (all ends).
Durham...hey you're ~30 miles away Nice day we are having....for the geese anyway.
Old Jan 22, 2012 | 06:31 PM
dpalmieri's Avatar
Default thanks
thanks poorman212-
I'll start in those places before moving on to think about starters or ignition switches-
yeah, rough weekend in our parts with all that cold, clouds and rain!
Old Jan 23, 2012 | 05:34 PM
My pleasure...another fine day we had today.
Hoping that it is something with the voltage getting to the starter and not the starter itsself. So that is why I'm suggesting to start there.
Do you have a volt meter? There are some other tests you can do to narrow things down.
Old Jan 23, 2012 | 10:46 PM
kings02's Avatar
Sounds like the starter is on its way out. I have a 97...It did the same thing. Took it to the shop and indeed the starter was the culpret.
Old Jan 27, 2012 | 03:37 PM
dpalmieri's Avatar
Default Starter fixed
My mechanic was convinced it was the starter, we replaced it and all seems well. Thanks much for tips + advice-
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
babylon888
Feb 16, 2006 02:08 PM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
