96' Accord -- Turns over but wont start
Old Mar 23, 2012 | 06:14 PM
  #21
Hondahonda's Avatar
Originally Posted by kyle102565
just because the distributor is new doesnt make it good. if you have power going in and nothing coming out, (i.e. secondary spark) the distributor is junk.
i put 4 distributors in my 91 accord in 4 years.
they eat them.
unlikely its a fuel issue, as for a vacuum leak, it should still start but run like ***
Rich porter is a Canadian made distributor, it's very good. Google it and you'll see how many people recommend one.
Also: it likes to idle rough at start, but if I can manage to shift it into reverse/drive before the engine stalls then it runs normally. doesn't that tell us something?
Old Mar 23, 2012 | 09:55 PM
  #22
Hey, would you answer these questions:
You put in new spark plugs, what brand did you use?
Where did you get the replacement distributor? Was is new? Did it come with the ignition control module (a small black piece with 4 wires plugged into it)? Did it come with a new distributor cap and distributor rotor?
Is the coil the original?
Have you cleaned the IACV and/or the FITV?
How about the EGR ports on the intake manifold?
Old Mar 24, 2012 | 01:42 PM
  #23
kyle102565's Avatar
i researched them and they are a dedicated company, but @&%! happens.
test it, if alls well than look at the injector and its signal, pull the #3 plug and read its condition. you could have a bad valve or a bad head gasket.
merely suggestions, a misfire can be diagnosed, follow the path.
Old Mar 24, 2012 | 01:43 PM
  #24
kyle102565's Avatar
as suggested, im thinking IAC
BlueEyes
Jun 24, 2013 07:35 PM
jmalek
Nov 7, 2011 11:24 AM
Lch05Srm
Aug 21, 2011 11:27 PM
themachinist1
Jun 22, 2011 06:41 PM
sdtundra
Mar 27, 2010 06:56 AM
