96 honda accord v tech slight oil leak underneath
Old Apr 2, 2023 | 05:40 PM
Buckeyebob's Avatar
Default 96 honda accord v tech slight oil leak underneath
Hi. Any info helpful? Don’t know what this cable is? Looks like it has a rubber seal that might be leaking? Or oil pan gasket? Thank you
Old Apr 2, 2023 | 08:54 PM
That looks like a throttle control cable from the throttle body to the transmission.
Oil flows down when you have an oil leak, so you need to inspect possible leaks above the oil pan.. One item to check is the oil pressure sending unit. It is above the oil filter and has a rubber boot that likely feels like plastic due to heat and age. That oil pressure sending unit can leak through the sensor. Also look at the valve cover gasket.
Old Apr 2, 2023 | 10:47 PM
Buckeyebob's Avatar
Default Thank you!!! Still learning how to reply and say thanks
Thank you. I will start where you suggested. Great info!!!!
curvenut
Apr 12, 2014 11:15 PM
skyfire322
Feb 28, 2013 08:50 PM
mishakol129
Oct 29, 2012 10:03 AM
twiceborn
Jan 8, 2008 07:46 PM
