97 abs sensor
Old Dec 23, 2011 | 01:57 PM
lmrj0030's Avatar
Default 97 abs sensor
Is there any place where i can see a DIY on this?
MY abs sensor light is coming on and i'm thinking of cleaning it first before getting it fixed.
Old Dec 23, 2011 | 02:35 PM
lmrj0030's Avatar
All right, so i cleaned the sensor and took off the black stuff that accumulated. But it's still giving the read. I guess i have to chance the whole piece
Is there a DIY on this? Thank you !
Old Dec 24, 2011 | 08:44 AM
Get the code(s). Once you know the code we can help.
If you already have the codes and it is one of the wheel sensors, you can measure the resistance of the sensor to see if it is good or bad.
Old Dec 25, 2011 | 06:12 AM
lmrj0030's Avatar
It's the rear driver side as said by my friend who has an abs reader
How do i check the resistance?
Old Dec 25, 2011 | 08:19 AM
First test is to dixconnect the harnes. Test the resistance of the sensor-your voltmeter (set to measure resistance), touch the leads to the wires going to the sensor- should be between 600-900.....more steps based upon what you find.
In the Common DIY Threads sticky at the top of this section there is a link to a manual you can down load that will help with this.
pondrun
Nov 8, 2021 09:40 AM
93Accord2.2
Nov 7, 2013 07:10 AM
wings
Jan 6, 2012 03:14 PM
kingkohlmn
Mar 6, 2011 08:13 AM
T WILD
Jun 10, 2009 06:45 AM
