97 accord 4 cyl o2
Old Apr 8, 2012 | 12:43 PM
jfman55's Avatar
Default 97 accord 4 cyl o2
i have a 97 4 door accord ex 4 cyl vtec. i need to change o2 sensor bank 1 sensor 2 which is it? is there a diagram? also what is it from autozone?....upstream downstream rear front? thanks
Old Apr 8, 2012 | 12:45 PM
jfman55's Avatar
is it Part Number: 13176 from autozone bosch?
Old Apr 8, 2012 | 12:47 PM
what code are you getting specifically?
Old Apr 8, 2012 | 12:53 PM
jfman55's Avatar
p0141
Old Apr 8, 2012 | 12:54 PM
jfman55's Avatar
i tried clearing but it comes back right away
Old Apr 8, 2012 | 01:30 PM
This code is for the secondary oxygen sensor that is downstream. It will be bolted into your catalytic converter or just after it.
I would say that you may want to test the resistance for the heater circuit. I think the electrical connector is under the driver's seat.
The car will still run fine without replacing that sensor. That sensor is for emissions on your car.
Denso makes the OEM sensor for your car. If you look at densoaftermarket.com, you may be able to order your part online that is an exact match for what you can buy through the parts dealer.
Old Apr 8, 2012 | 02:02 PM
jfman55's Avatar
why denso? on autozone bosch has 1 year warranty while denso 234-4601 has 3 months?
Old Apr 8, 2012 | 04:17 PM
Denso is Honda OEM O2 sensor brand. Sometimes, people replace their O2 sensor with a Bosch and the code still remains until they change it to a Denso. Denso also last a very long time.
On a side note, there was an independent Honda mechanic that mentioned to me (on another forum) that he found some Bosch O2 sensors to be repackaged Denso sensors.
Old Apr 11, 2012 | 09:37 AM
I found that once... I've bought Bosch O2 sensors before for the VWs & Saabs and they were actually Bosch sensors. When I got one from AutoZone for a Honda (I think it was for the 95 Integra) the Bosch carton contained a Denso O2 sensor.
mrmatrix
Aug 12, 2006 05:39 PM
trip1980
Jul 14, 2006 11:41 PM
tom77
Jan 21, 2006 08:56 AM
nman
Jan 11, 2006 11:52 AM
MI_CM_ACCORD
Sep 27, 2005 04:42 PM
