97 Accord ABS Light stays on. Uploaded pic, and video of Diagnostic Code
Old Oct 28, 2012 | 10:44 AM
It could still end up being a leak or a bad unit.....but before I would replace the unit....the bleeding only costs a bit of time and fluid.
Old Oct 28, 2012 | 10:48 AM
Here is the write up by Jim if you don't have the means to do it by the TSB
https://www.hondaaccordforum.com/for...systems-31259/
Old Oct 28, 2012 | 12:17 PM
Custnam's Avatar
Thumbs up
HEY GUYS!!!
I fixed it!!! Well I did the physical work, but you guys and your brains did the rest. I bled the ABS reservoir just as your instructions said and sure enough there was a ton of bubbles and air trapped in there. I think it might have a leak and the reservoir was close to empty and sucked in some air. But as of right now the light is off and staying off. Test drive it also. Then cleaned it up real good so I can check again and try to locate the leak if there is one. But anyway I just wanted to thank you guys, my father in law is going to be so happy.
Old Oct 28, 2012 | 12:32 PM
Good to hear....hope it holds.
If not,,,,,there is an o-ring that fails quite often, Search the DIY section for ABS fix....I think the title has a price of like 1.50 something..........hate getting old.
Old Oct 28, 2012 | 12:49 PM
There is a TSB about the body plugs (9 if I remember leaking). You have to remove the modulator to access them, remove, clean, reinstall tightly. This fixed a leak on one modulator I had.
Another leak site is the accumulator/modulator oring seal.
Old Oct 28, 2012 | 12:50 PM
Custnam's Avatar
Thanks again, fingers crossed its good for now.
dlite922
May 3, 2013 06:39 PM
dabro22
Feb 11, 2013 08:46 PM
honda2K
Apr 27, 2011 10:51 PM
Trickster
Sep 13, 2007 11:00 PM
abhijitgp
Aug 18, 2007 07:57 PM
