97 Accord Tranny slipping sensation
Old Oct 22, 2012 | 10:53 AM
MoeSoJdm215's Avatar
Default 97 Accord Tranny slipping sensation
Hi everyone, ok so heres whats my problem, i bought a preowned 97 accord with a bad trans. I replacedthe trans as well as the torque converter. Reason being is the old owner said it would neutral out in all forward gears but would reverse in reverse. its still doing the same thing, I'm thinking it's something electrical. Can someone please help me with this issue. Thank you
Old Oct 22, 2012 | 11:02 AM
bostongrun's Avatar
What do you mean by "neutral out" ?
Did you install the transmission or did a shop do it?
How did you install the torque converter? Did you bolt the torque converter to the flex plate first or vice versa?
Old Oct 22, 2012 | 11:39 AM
By neutral out I mean I have it in gear and I press the throttle and it's as if its in neutral and I did the.work the torque converter clicked in 3 times the converter bolts lined up with the flex plate there were 8 converter bolts. My last step was bolt the converter to the flexplate.
Old Oct 22, 2012 | 07:25 PM
Check for codes and let us know if there are any. From there test the solenoids and the connectors.
The trans in the 5th gen (94-97, like you have) are pretty solid. So two bad ones is hard for me to understand.
Old Oct 24, 2012 | 06:40 AM
Vulcan's Avatar
Sounds like it could be the transmission, possibly. Did you get a warranty?
joetahoe
Feb 3, 2010 06:04 PM
yeding
Jan 16, 2009 06:52 AM
SteveO_f22a
Oct 26, 2007 11:12 AM
kornfox
Mar 29, 2007 05:37 PM
Mechhead
Jan 24, 2007 10:19 PM
