97 Honda V6 Oil Leak
Old Apr 29, 2014 | 06:01 PM
TexomaAccord's Avatar
Default 97 Honda V6 Oil Leak
Oil is leaking from somewhere under the distributor... Its not leaking IN it, but under it, causing oil to get all over the bottom of the cap...
Ideas?
Old Apr 29, 2014 | 08:43 PM
holmesnmanny's Avatar
an oring goes around the distributor shaft sealing off oil from leaking ... just pick up another distributor oring
Old Apr 29, 2014 | 10:22 PM
x2 on the distributor o-ring. Could be valve cover gasket. Has any recent work been done on your car not long before you noticed the oil leak?
Old Apr 30, 2014 | 12:47 AM
negative on valve cover. I bought two new ones thinking it may be one of those, but in the wrong location. - they werent leaking
Now the side cover gasket is leaking as well (v6)
I bought this thing and it was already covered in oil
When I bought a new distributor cap to put on, the old one was very very dirty on the bottom.
I cleaned out the inside of the housing for the rotter, I'll double check to see if its leaking from under or in, but Im thinking under
Old Apr 30, 2014 | 01:55 AM
Oh, if it's leaking in the inside then you need the inner seal as well in addition to the oring that goes around the shaft. You will need to see if it's a hitachi or tec as they both take a different internal seal.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
