97 tranny
I just bought my daughter a 97 accord, 4 banger and auto, I was wondering if the tranny shifts hard normally or is it something to get looked at. It doesn't slip or anything and if you ease the throttle up it shifts fine, but if you are on the gas a bit it shifts hard through the gears.
drain and fill plus 1 can of lube guard for imports. IF there is no evidence of a trans fluid change use a machine that allows the pump in your transmission change out the fluid with NEW HONDA ATF FLUID plus 1 can of lube guard for imports. Those transmission do shift quite firm and the new fluid and lube guard will get it back to where it should be provided that there is nothing mechanically wrong with the transmission. I had a '94 that I sold at 146K and new owner has 150K on it now.
Hello new member..shifting hard is not supposed to be with any car unless your in a drag race..have it looked after is my suggestion:
Welcome to the forums, were happy to have you with us!
WheelbrokerAng [sm=americanasmiley.gif]
ORIGINAL: WheelBrokerAng
Unfortunately it is true with the older accords, they DO shift firmer as they age and the lube guard and fluid change works as advertised. I had a 94 that shifted fairly hard when i got it at 87K miles and I found that advice and followed it and the problem was gone within a few miles....
cbold681
Feb 28, 2011 06:47 PM
