97 tranny
Old Nov 19, 2006 | 11:52 PM
IRNDN00
Default 97 tranny
I just bought my daughter a 97 accord, 4 banger and auto, I was wondering if the tranny shifts hard normally or is it something to get looked at. It doesn't slip or anything and if you ease the throttle up it shifts fine, but if you are on the gas a bit it shifts hard through the gears.
Old Nov 20, 2006 | 12:47 AM
19Accord97
Default RE: 97 tranny
What trim level is it? Mine is an LX and seems to shift harder than other cars. Hard shifts are actually easier on a transmission though and extend their lives.
Old Nov 20, 2006 | 10:35 AM
YeuEmMaiMai's Avatar
drain and fill plus 1 can of lube guard for imports. IF there is no evidence of a trans fluid change use a machine that allows the pump in your transmission change out the fluid with NEW HONDA ATF FLUID plus 1 can of lube guard for imports. Those transmission do shift quite firm and the new fluid and lube guard will get it back to where it should be provided that there is nothing mechanically wrong with the transmission. I had a '94 that I sold at 146K and new owner has 150K on it now.
Old Nov 20, 2006 | 02:05 PM
Hello new member..shifting hard is not supposed to be with any car unless your in a drag race..have it looked after is my suggestion:
Welcome to the forums, were happy to have you with us!
WheelbrokerAng [sm=americanasmiley.gif]
Old Nov 20, 2006 | 02:20 PM
ORIGINAL: WheelBrokerAng
Unfortunately it is true with the older accords, they DO shift firmer as they age and the lube guard and fluid change works as advertised. I had a 94 that shifted fairly hard when i got it at 87K miles and I found that advice and followed it and the problem was gone within a few miles....
Old Nov 20, 2006 | 02:38 PM
IRNDN00
Thanks for the advice I will change the fluid as soon as possible.
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
1993accordSE
Mar 18, 2005 03:01 PM
surfnsmps
Dec 2, 2004 05:48 AM
