98 accord cranks but won't start
Old Dec 23, 2013 | 05:16 PM
Almanzar23's Avatar
Default 98 accord cranks but won't start
Hey guys I hope you can help me. I've been trying to figure out what's wrong with my car. It cranks but it won't start. It didn't have spark so I changed the distributor and that problem was solved but still didn't start. And I also changed the main relay. I can hear the fuel pump engage. Please help me
Old Dec 23, 2013 | 05:25 PM
You haven't definitively established whether spark or fuel is the cause of no-start.
Suggest attempting to start w/ throttle body cleaner or starter fluid injected for 10 secs into air intake duct.
If no-start continues, then spark is missing. Check for 12V to blk/yel wire at the distributor connector.
If engine starts and runs briefly then spark is good, and fuel delivery is the problem; low fuel pressure, injector system fault (no injector fires).
Try this test and post your findings.
Old Dec 23, 2013 | 05:37 PM
Almanzar23's Avatar
Ok tried the starting fluid and it didn't work. Then I check for voltage and it's reading 10.92
Old Dec 23, 2013 | 06:49 PM
Low voltage may cause spark to be too weak to start engine. You should have battery charged and load tested.
Old Dec 23, 2013 | 08:08 PM
Almanzar23's Avatar
I tried it while using jumper cables too.. So I don't think that's the problem. Someone told me earlier that the ecu might be bad. Could that be the problem?
Old Dec 23, 2013 | 08:22 PM
No spark might be caused by ECM, but weak spark is unlikely. Suggest checking to confirm a spark is still being generated at plugs.
If you have a timing light, suggest checking that #1 is firing near TDC.
Any other recent work on engine? Distributor has a ground near thermostat that can cause no-start if loose or corroded.
Suggest also checking for spark leakage at distributor cap and ignition wires w/ water spray over parts. Look for sparks jumping at night when visible. Replace faulty components.
maddogtheman329
Mar 26, 2012 03:15 PM
Spectre
Jan 17, 2010 06:08 PM
jjrho
May 4, 2008 10:22 PM
LiquidR1
Sep 2, 2007 09:26 PM
thomks
Aug 15, 2006 06:43 PM
