'98 Accord Headlight Problem
Old Jul 21, 2012 | 11:07 AM
double_N's Avatar
Default '98 Accord Headlight Problem
My right headlight will not turn on unless i open the hood and slam it down. This happens every time I need to turn the lights on. Sounds like a bad connection somewhere or possibly a short in the wiring.
Does anyone have an idea where I should start looking for a bad connection or any other ideas where I should look for the problem.
Old Jul 21, 2012 | 11:18 AM
A few things I'd check. The ground. Then also inspect the connection and the wires to the bulb.
When you say "right"....this is the right/pass side headlight...corrct?
Old Jul 21, 2012 | 12:38 PM
Dr. Drivability's Avatar
check the continuity in the bulb first before you start chasing wiring problems.
Jager06
Mar 11, 2010 09:31 PM
slow1500
Mar 18, 2009 07:47 PM
CoryTheStory
Nov 18, 2008 03:00 PM
lyle
Jun 4, 2008 12:36 PM
