98 Accord LX headlight help
Old Jan 8, 2009 | 04:43 PM
apple123
Default 98 Accord LX headlight help
Low light bulb on the passenger side does not work. Checked the fuse, replaced the bulb. Still nothing. Any ideas? Is there any possibility I have the wrong bulb? All sources call for 9006 12 V 55 W halogen, but that bulb is single prong and the original bulb is double prong. I got a 9005 on the recommendation of a sales rep. It fits, so I don't think it can be the bulb. No other problems with the electrical or other systems. I'm confused! Can it be wiring? If so, what should I check?
Old Jan 8, 2009 | 06:20 PM
Default RE: 98 Accord LX headlight help
If you have volt meter, unplug the faulty headlight. Turn on the headlight. Use a volt meter touching a lead to each pin on the connector. You should have 12V.
If no voltage, then either the ground is bad or there is a problem with the power side. Probe one pin of the connector and ground the other probe on the engine block. One pin should read 12V (power side) and the other should show zero volts (ground side). If both are zero, then no power is getting there and you will need to identify the problem upstream (fuse or relay). If one pin has 12V, then the ground is bad on the connector.
Old Jan 8, 2009 | 06:24 PM
wilmer007
Check your relay fuse. my 94 accord lx decided to turn off my headlights in the middle of driving, in the morning i checked the fuses and they were good, then i checked the relay fuse and boom problem solved...
Old Jan 9, 2009 | 09:20 AM
apple123
Thanks for the replies! I will check out both suggestions this afternoon.
nickusmp
May 18, 2012 05:52 PM
illotoko
Mar 10, 2012 10:40 PM
mamtsberg
Mar 17, 2010 09:15 PM
Fez
Mar 10, 2007 05:01 AM
