98 Accord not revving past 2500prm
Old Feb 12, 2014 | 05:40 PM
Sonny75's Avatar
Default 98 Accord not revving past 2500prm
Hello people, I have a 98 2.3 honda accord, 5sp manual. it lost power while driving, and has gone into a limp mode. It fires up fine, idles perfectly, but when you try and rev it, it feels like it has a limiter. There is also a hum/whistle from a belt. I purchased a scanner, but it only showed p0135, which i know about as the cat has been shot for a while. there have to be more codes, im returning the scanner. any pointers? or anyone have something similar?
please help. thanking you all in advance.
Old Feb 12, 2014 | 06:49 PM
P0135 is open/short in the primary (bank 1, sensor 1) O2 sensor heater circuit.
Catalytic converter may be so badly damaged that engine breathing is impacted (blockage in converter).
Moved your post to correct forum. Read forum posting rules.
Old Feb 13, 2014 | 07:26 PM
Sonny75's Avatar
Thank you chap. sorry I'm new to forums, didnt know I was in the wrong forum.
I have checked the exhaust, its clear. I'm waiting for a new scanner. It feels like there is a limiter with a loss of power. At idle you cant tell a thing. when revved, the humming noise returns, I'm stumped.
Any other ideas people??
many thanks
Old Feb 14, 2014 | 08:45 AM
How long since Timing Belt has been changed? Slippage in TB can cause performance problems. Suggest checking camshaft is at TDC when crankshaft is brought to TDC on timing pointer.
O2 sensor heater should not cause a rev-limit, but other related problems; poor o2 sensor performance or fuel injector problem.
Can you check long term fuel trim (LTFT) from ObD2 system w/ your scanner?
Jason02Accord
Feb 16, 2016 11:25 PM
ebby2000
Mar 7, 2014 09:49 AM
cornfed85
Feb 28, 2012 04:59 PM
zairas
Nov 21, 2008 11:47 PM
