98 accord shuts off while driving, immediately starts back up
Old Feb 8, 2011 | 07:37 PM
colorado_accord's Avatar
Originally Posted by SFLACCORD
What did you install? Did it happen rarely or have a habit of doing it?
At first it happened once every couple weeks then gradually more often, twice in one day and then I replaced the electrical portion of the switch. Located on the left side of the steering column, opposite the keyed portion.
Old Feb 9, 2011 | 11:10 AM
stir_fry_boy's Avatar
Replace your main fuel relay. It is bolted to the steering column underneath the dash. Should be about $60. This is a known issue when it gets hot outside. Could also be an ignitor or coil.
Old May 25, 2026 | 11:59 PM
Lexx's Avatar
My 2.3 vtec is great. Im pushing close to 240,000 miles. Being in South Florida, the cold is not an issue.
But recently, while driving at any speeds, the car has completely shut down. I would then coast to a stop and pull over. I turn the key completely off, say "WTF", and in no time, try to restart it. It starts, no problem, every time. I go on my way.
One code on the diag., is the EGR valve should be replaced, but the mechanic didn't think this valve would cause the vehicle to stall. The car even stalled once in idle.
Thankfully every time this has happened, I was able to coast off the road.
Whatever I need to do to fix it, but I wanted your opinions first to see if there has been any other experiences with this issue. Thanks for the replys and advice
I had the same symptoms. My 98 Honda Accord started shutting down while driving. No codes were issued. I'd restart it immediately and it would run fine. I checked the engine air filter and it was very dirty. I replaced the air filter and the car has been running well with a lot of pep since.
Mabworks
May 16, 2019 11:57 PM
9495Honda
Jan 23, 2012 07:14 PM
gdannboy
Feb 28, 2011 02:24 PM
vprevot1
Feb 21, 2010 07:14 PM
XZiler8r
Feb 16, 2007 09:15 PM
