98 Accord start up problems
Old Jul 15, 2009 | 12:08 PM
I just looked too without any luck. I'm starting a cleanup campaign on the DIY board, to make this stuff easier to find.
The EGR valve is #13. Check for carbon build-up in the hole underneath the EGR valve.
I'm not sure, but I think beginning in 1998 the EGR ports are not the same small restrictive passageways so they're not as difficult to clean. Or not as likely to plug up.
The EGR passageway goes from the valve over to the intake manifold gasket, to an opening you can see at the lower right of the gasket. I'm not real sure how it goes from there to each intake port. Hopefully it doesn't require you to remove the intake manifold.
Old Jul 15, 2009 | 01:00 PM
deserthonda's Avatar
there is a bulletin on this, call the Honda dealer see if you qualify or they might help with monetory wise
Old Jul 15, 2009 | 10:13 PM
v_ryu6
So today I ran a few errands and after my first stop, I tried to start my car and it wouldn't start. Normally I can give it some gas and it will start up reluctantly and then run fine when running. This time is wasn't working. After about 10 minutes and several tries, I tried it again. I gave it some gas and it started but the engine was making a sound like "womp womp womp" It kind of sounded like a helicopter. I got a little nervous so I let off the gas and the engine stopped running. I did it once again about 10 minutes later and it had the same sound but this time I held the gas at about 3k RPM for a few seconds and then the idle stabilized.
I drove straight to a mechanic and explained to him what happened. My car started right up perfectly when at the mechanics. I started up the engine about 5 times and they started all 5 times perfectly normal.
I hope this can help figure out what exactly is wrong.
Old Jul 16, 2009 | 11:38 AM
v_ryu6
The mechanic I took my car to told me that the clutch is the reason why the car isn't starting up. I knew that my clutch was going, but could this cause startup problems like described in my last post?
Old Jul 16, 2009 | 01:37 PM
00AccordLX5spd's Avatar
Registered User
Your clutch has nothing to do with the engine problem. Time to find a new mechanic. I clutch is one of the most expensicve things to replace. Sounds like he is trying to make some money off of you.
If the code says there is something wrong with the EGR, you need to adres that before anything else. it will likely solve your problem.
As DH said, there is a TSB on it and a dealer may do it for free if your car is covered by the TSB. You need to call a dealer and tell them the code and give them your VIN# to see if your car is covered under the TSB.
Tony1M
Nov 6, 2023 08:29 PM
kshonhng
Jul 26, 2012 08:33 AM
Hanktjy
Mar 8, 2012 08:53 AM
05HondaAccord
May 5, 2008 11:24 PM
KimberlyC
Apr 16, 2006 11:51 AM
