98 Accord starts, then stalls right away and won't restart
Old Jul 9, 2007 | 12:46 PM
rummermail
Default RE: 98 Accord starts, then stalls right away and won't restart
I added 4 gallons of gas which put it back to half a tank.It started right up!
Old Jul 11, 2007 | 12:25 PM
rummermail
I may sound stupid but where is the banjo nut? I have a full tank of gas and it did it again at lunch. yesterday I parked under shade and I had no problems.
Old Jul 11, 2007 | 12:41 PM
Did you try listening for the fuel pump? If no fuel pump noise is heard when you turn keyswitch to ON, there's no point checking for fuel pressure.
Banjo bolt is the large bolt (17mm usually) that holds the end of fuel line from fuel supply to the fuel rail. There is an aluminum washer underneath it. Don't loose it! Bolt will be tight. There may be a small ( 12mm) bleeder bolt on the fuel rail also. It may be easier to reach and crack open.
good lukc
Old Jul 11, 2007 | 01:25 PM
rummermail
I am also goin to pull the main relay and check the solder joints,Since I am work I fix the solder here. Is it easy to remove? Any suggestions?
Old Jul 19, 2007 | 02:58 PM
rummermail
Thanks for all your help. It has been 1 week since I fixed the solder joints on the main relay and no problems with starting. The temp with the heat index has been arounf 120 degrees.
Old Jul 19, 2007 | 03:03 PM
sir_nasty's Avatar
Great! Glad it was fixed and sounds like it was a simple thing for you to repair, it's always good to hear when something works out!
around 120? Where are you located? CA?
Old Aug 2, 2010 | 04:03 PM
  #17
vtechic's Avatar
Originally Posted by 00AccordLX5spd
x2. You car was made to run on 87 octane gas. 93 will not help at all. Some are of the opinion the car actually runs worse with higher octane gas if the engine was not designed to run on it.
read the manual before you take someones advise!!! it recommends 89 shell for your 98' accord, if we have the same owners manual, and i bet we do.
MichaelT1960
Jan 28, 2019 05:42 AM
mcneil86
Sep 5, 2014 08:07 PM
HondaAccord93
Jul 18, 2010 03:37 PM
irhunter
Apr 5, 2010 07:34 PM
shmzr
Aug 10, 2009 01:38 AM
