98' Honda Accord EX CYL Acceleration Problems - CODES
Old Jan 25, 2011 | 02:23 PM
techjohnny's Avatar
Default 98' Honda Accord EX CYL Acceleration Problems - CODES
Here are the codes that were triggered.
P0171
P0763
P1705
P1298
Hopefully they're all related. The transmission does not slip, but the car sometimes struggles 0-20.
Thanks.
Car is automatic 4CYL
Old Jan 25, 2011 | 08:33 PM
P0171 = system too lean
P0763 = auto-trans; stuck in 4th
P1705 = AT; no shift except 2-3; L-U-Clutch not engaging
P1298 = ELD high voltage
Reset your ECU & see if they ALL come back (or have you already done that?)
I'm no expert on auto-trans.
ELD = electrical load detector. It's built into the engine-compartment fusebox. It measures electrical loads so the engine can do a better job holding a steady idle.
Old Feb 1, 2011 | 12:11 PM
techjohnny's Avatar
Reset the codes, and my check engine light HAS NOT come back on. It doesn't seem to be driving funny anymore, but it was suggested that I change my transmission fluid.
Thanks,
--tj
Old Feb 1, 2011 | 04:50 PM
Changing your trans fluid isn't a bad idea just from general good-maintenance.
Occasionally a low system voltage (flaky battery??) will trigger strange errors that never come back.
Old Feb 3, 2011 | 09:29 PM
techjohnny's Avatar
Codes that seem persistent:
P0171
P0170
Thanks car is still having problems with power.
marysmom
Mar 31, 2012 07:30 AM
techjohnny
Jan 15, 2011 09:32 AM
voteforpedro
Oct 28, 2009 11:53 AM
voteforpedro
Oct 6, 2009 02:54 AM
mrmatrix
Aug 12, 2006 05:39 PM
