99 accord coolant bypass
Old Jun 10, 2011 | 04:46 AM
tattootoe's Avatar
Default 99 accord coolant bypass
Hey guys,
I have a 99 Accord and little problems are popping up here and there so I figured Id find a good place to talk tech.
Most recently, like just a few hours ago. What Ive narrowed down to as the bypass tube under the manifold broke off (corrosion) and was just dumping water and overheating pretty quick. I was out of town and needed a quick fix, so I clamped off the tube and plugged the manifold side. Seems to be holding as it got me home with no problems.
My question is, having done this, am I creating any serious issues? I plan on getting it fixed asap. I just don't want to damage anything else in the next couple of days.
Thank You
Doug
Old Jun 10, 2011 | 05:48 AM
piggylover1985's Avatar
You're not talking about the big pipe coming out from the back of the water pump right ?
Old Jun 10, 2011 | 06:21 AM
tattootoe's Avatar
Its 1/2" rubber tubing that comes out of the thermostat cover and into a fitting at the bottom of the air intake (this is the fitting that is broken off). Some minor research said that this is a/the bypass.
Old Jun 10, 2011 | 06:28 AM
engtaz's Avatar
Almost A Senior Member
I believe that hose is use for heating the intake air on cold days but is not essential.
Old Jun 10, 2011 | 06:39 AM
tattootoe's Avatar
Some more research turned up an upgrade of some sort bypassing this. This is a pic. The connection Im talking about is B. Its broken off, and I just plugged both sides to keep the coolant from dumping out.
Old Nov 9, 2024 | 10:07 AM
CodyMorse's Avatar
Originally Posted by tattootoe
Hey guys,
Thank You
Doug
how to replace coolant crossover pipe
PJ_STYLES_95AccordEx
DIY Answers.
Apr 3, 2017 06:05 PM
shan5
May 18, 2011 09:36 AM
fd1836
Mar 22, 2010 01:38 AM
hoppl04
Sep 22, 2009 11:34 AM
tsoileau
Mar 14, 2009 07:22 PM
