DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Short belt to bypass A/C on 94 - 95 Accord
Old Jul 24, 2011 | 07:59 PM
PJ_STYLES_95AccordEx's Avatar
Default Short belt to bypass A/C on 94 - 95 Accord
My a/c compressor pretty much seized up on me a few weeks ago and now the pulley bearings are almost shot. I am just going to bypass the a/c compressor with a new shorter v-ribbed belt for now. Anyone ever done this on a 94-95 accord 4 cylinder and have a part number for a belt? Thanks.
Old Jul 24, 2011 | 08:28 PM
The belt that you want to get would be for a 94/95 DX accord that came without a/c. The is the Gates Belt part number K060370 for a 95 DX without a/c. There are likely other brands that you can look up at the parts store web sites.
I am not sure the belt will clear the a/c compressor pulley. You would have to remove the clutch and pulley from the a/c compressor. The alternative is to remove the whole compressor, and the shorter belt will definitely work. I did that on my 95 when I repaired the seals on the compressor.
Old Jul 30, 2011 | 03:23 PM
Thanks PAhonda. I actually found the Dayco part #DY5060370 as well. I called up NAPA and they cross referenced the Gates number and I installed my new shorted belt bypassing the A/C pump and it worked out perfect. If anyone else needs the NAPA part number it is Micro-V belt 060370 or K060370. The dimensions are 27/32" x 37 - 5/8" or 21 mm x 955 mm.
Old Jul 30, 2011 | 06:53 PM
Good information with part numbers. I'm gonna move this into DIY.
Old Apr 3, 2017 | 06:02 PM
Tc 97AccordEX's Avatar
The bypass belt for the 94-97 honda accord ex is not 21mm-955 mm that belt is waaaay to big it is the k6 370
Old Apr 3, 2017 | 06:05 PM
Default Demi
the demensions are wrong its 370mm the 955mm is way to long
tattootoe
Nov 9, 2024 10:07 AM
SevenFour
May 18, 2012 12:33 AM
shan5
May 18, 2011 09:36 AM
fd1836
Mar 22, 2010 01:38 AM
hoppl04
Sep 22, 2009 11:34 AM
