99 Accord DX 2.3L - Head Gasket Endeavor
Old Oct 20, 2013 | 09:25 AM
  #21
MasterK's Avatar
Used or new parts needed to replace. Check w/ Honda Parts.
Chase threads on coolant temp sensor w/ a tap. If you don't have experience w/ a tap, then get someone else to do this.
I've identified the middle and right one. I may have to go junk yard hunting for the left one, some type of water outlet.
Old Oct 20, 2013 | 10:17 AM
  #22
Be careful, the temp sending unit - the right one in your pic - should be "pipe thread", if memory is correct 1/8th inch "pipe" thread.
Old Oct 20, 2013 | 11:27 AM
  #23
If the threads are messed up on the sender, get another sender. The sender is harder than the aluminum head, so a new sender avoids damage to the threaded hole in the head.
Old Oct 20, 2013 | 11:34 AM
  #24
MasterK's Avatar
I'm not understanding what you're implying. Do I need to do something before installing it? Or are you just saying I need to make sure it has correct thread specs?
Old Oct 20, 2013 | 11:40 AM
  #25
MasterK's Avatar
I have already ordered a new sender. My main concern is the water outlet coupling. It was corroded all the way through, affecting even the aluminum threads in the head. I'm surprised that shop didn't notice enough to query whether I wanted that addressed. I can't even identify the part, let alone wonder about the thread issue.
Old Oct 20, 2013 | 11:52 AM
  #26
That hose nipple (#10 in picture) is 19500-PT0-000 and maybe $10 or less at the dealer.
Old Oct 20, 2013 | 04:27 PM
  #27
MasterK's Avatar
God Bless you sir! Thank you!
Old Oct 20, 2013 | 05:54 PM
  #28
draser's Avatar
Another thing, you'll need to do some block prep before installing the head and gasket. I normally take pistons half way down, stuff bores and cooling ports with paper towel, and use 400 grit wet sand paper on a sanding block to clean contact surface. Since the engine overheated, I'd check block for warpage with a straight edge. I normally use OEM headgasket just for the pain this job is. I sold my manual, but there's a tightening sequence, in 2 stages with specific torques, and I believe an angle finish torque; somebody with a manual may help. Before reassembling make sure to rotate crank to line up marks, just like for timing belt job. Make sure the head sproket is also lined up, don't need bent valves.
Old Oct 25, 2013 | 05:28 PM
  #29
MasterK's Avatar
I now have all the new parts, do I need to put anything like lock-tite (Honda-bond?) on the threads before installing?
Old Oct 26, 2013 | 10:53 AM
  #30
I might put some teflon tape on the water "tube"?
