99 Accord DX 2.3L - Head Gasket Endeavor
Old Jan 14, 2014 | 12:01 PM
  #61
MasterK's Avatar
Originally Posted by PAhonda
what are the wire colors going to the TPS. There are three wires on that connector.
Not sure, but I found the IACV and I'm not sure I'm going to attempt to clean it. It's pretty nasty.
Attached Thumbnails 99 Accord DX 2.3L - Head Gasket Endeavor-cam0001_edit_1389669631284.jpg   99 Accord DX 2.3L - Head Gasket Endeavor-cam00016.jpg
Old Jan 19, 2014 | 10:04 PM
  #62
MasterK's Avatar
Default Success!!!
Thank you all for the help. The idle air control valve was the culprit. We have normal starting idle of about 1100-1200 rpm at cold start leveling off to 750rpm at operating temp. I changed the oil again, and it's looks more normal. First time forgot to change the filter, so there was still some contaminated oil in the mix. I'm also working on flushing the cooling system. I did a physical flush where you cut the inlet hose and put a flushing "T" while running the car. Definitely forced some more crap out. Now I'm running Prestone's chemical flush for 3 days. No overheating, runs good. I had to unexpectedly replace the alternator that was causing a noise the seller said was "just the Accord sound". Right. So it now has the same issue when I first got it. Low idle vibration which I have or will start another post for. Anyway, I'm pretty much a happy camper. The car I bought in Sept, can now be driven!
toddyfresh
Jul 25, 2007 01:57 PM
thunder_x
Jul 9, 2007 11:57 AM
htownfanatic
Jun 24, 2007 09:54 PM
mdd0127
May 21, 2007 09:27 PM
dodins
Mar 18, 2007 08:10 PM
