99 Accord EX V6 - Climate Control Panel Question
Old Feb 27, 2013 | 11:28 AM
Homestead'er's Avatar
Default 99 Accord EX V6 - Climate Control Panel Question
I was searching around for others whom may have had the same issue my car recently is experiencing. I have read some threads relating to the climate control panel being the culprit for intermittent A/C problems, but I could not find any relating to Auto Heat....
I will be driving my car at hwy speeds and the heat (set in Auto mode) will just shut off for just a few seconds and then the blower kicks back on to the same exact setting. I can also manually just hit the auto mode button again and it comes back on.
Sorry, I am not much of an electrical expert! Just want to know if the A/C and Heat intermittent issues would be one in the same or not?
Thanks!
Nick
Old Feb 27, 2013 | 07:44 PM
Check for any HVAC codes as a start.
Are you saying that the blower stops working yet the HVAC "says" it is on?
Old Feb 28, 2013 | 07:48 AM
There are no check engine lights, etc. on and no, it completely shuts off when it occurs - blower and HVAC control area. Actually, since my post - it has stopped kicking back on after a few seconds, however, I am still able to manually just hit the auto button and it comes back on just fine.
Could this be a resistor problem? I know that is located under the glove box area. Just thinking or would that issue cause a complete failure???....I thought when a resistor went bad, it mainly effected non-auto systems and would cause, for example, fan position 2 or 4 (etc) to be non-functional.
-Nick
davidn32
Jan 28, 2013 12:48 AM
sona1111
Dec 3, 2012 06:09 PM
S-F
Apr 21, 2011 10:28 PM
bug176
Jun 27, 2008 11:56 AM
greenbean
Sep 21, 2007 03:14 PM
