99 Accord gets hot when stopped at light
Old Aug 5, 2012 | 11:36 PM
savatage4's Avatar
Default 99 Accord gets hot when stopped at light
O.K. here it goes, as long as i'm driving temp gauge stays under 50% but when I stop it starts climbing to 90 - 95%. but if I rev it up a few times it will briefly drop down. I have changed t-stat, coolant, thermo switch ( the one thats on the t-stat housing). both fans do come on when a/c is on, but not otherwise. I jumped switch they came on, but will not come on by themselves. Any ideas. Thanks in advance
Old Aug 6, 2012 | 10:12 AM
Did you bleed all the air out of your cooling system? When it's cold, squeeze the radiator hoses. If there's air they will feel/sound different, sloshing sounds, etc.
Then I would have suggested the fan switch in the T-stat housing but you already replaced that. What kind, what part # did you get? Someone around here might be able to look up parts cross-reference for that.
kevin1517
Sep 5, 2012 10:23 PM
sunskymech
Dec 20, 2010 06:56 PM
ali.j
Oct 7, 2009 10:35 PM
Johnene
Jul 7, 2009 08:28 AM
Jahsaccordcoupe
Dec 1, 2007 12:06 PM
