'99 EX V6 C.E.L. codes P0706 and P1457
Old Dec 26, 2012 | 02:06 PM
KaOS311's Avatar
Angry '99 EX V6 C.E.L. codes P0706 and P1457
Hey Everyone.
So here is the situation so far:
About a week ago, I replaced the vapor canister purge solenoid, the vent shut valve, and the two-way valve on the EVAP system to get rid of a P0420 (Catalyst System efficiency below threshold). After resetting the system and driving about 85 miles, these two codes came up:
P0706: (Open in transmission range switch circuit)
P1457: (EVAP emission control system leak detected [control canister system])
I am really asking about the first code. I know it can be a number of things and I just need some help troubleshooting. The car runs and shifts perfectly - no shudders or anything at all.
The second one just pisses me off. I fixed all of those parts, so maybe I did something wrong / something came loose. I am going to inspect my work and if I don't find anything, I'll try a new gas cap maybe.
I really need some help with this transmission circuit though, any help is very appreciated.
Old Dec 27, 2012 | 09:50 AM
Dr. Drivability's Avatar
not seeing code P0706, but P1706 is for the trans range switch, have to do the continuity test for the switch first...if it's bad, replace it. as far as the EVAP sys code, go back and double check all your original work first.
Old Dec 29, 2012 | 08:09 PM
KaOS311's Avatar
I double checked the work as you suggested and found no unplugged hoses, missing parts, bolts, etc. and found nothing wrong. Could have also been a loose gas cap, i'll reset the computer and see if it comes back.
If I have a bad switch, wouldn't I feel a problem in shifting? It shifts very smoothly. I will do the continuity test (I have a Haynes manual) but I need to get my hands on a multimeter first.
Old Jan 2, 2013 | 02:24 PM
KaOS311's Avatar
Ok I checked for continuity and the position sensor is fine, everything works as expected. I looked up some diagrams and I was wondering if maybe the fact that I put aftermarket LED's in my dash could be causing this error code? This sensor is connected to that column of lights in the dash cluster and I am wondering if the new bulbs I put in are throwing off the circuit.
IndioGray
Mar 9, 2012 06:05 PM
hondadude
DIY Answers.
Mar 2, 2010 09:21 AM
Moddage
Oct 19, 2009 12:45 PM
BLuEPiTBuLLz
Jul 15, 2007 04:28 PM
zoominhuman
Mar 30, 2007 06:55 PM
