9th gen accord v6 what to look for
Old Jan 5, 2019 | 10:34 AM
Dan125947's Avatar
Default 9th gen accord v6 what to look for
I’m looking to purchase a 2014 accord touring v6. I’ve not owned an accord since 91. When I check the car out at the dealer what should I look for? Other than the obvious “check the oil, make sure all the fratures work inside, look for abnormal tire wear etc.” is there anything specific to 9th gens that I should look out for?
Old Jan 5, 2019 | 11:24 AM
Seanjordan20's Avatar
You can tell a lot by a CARFAX. Make sure you see the carfax and analyze it. Pay attention to what it went to the shop for and how many times. They are good cars but some owners fail to take care of them. How many miles does it have on it?
Old Jan 5, 2019 | 02:35 PM
Dan125947's Avatar
i got the carfax. It does have one minor accident which I Knew about. (Part of the reason the car is priced Lower than average). The car only has 40000 on it so there are only 3-4 service records and probably not much wrong with it. The service records it does have don’t go into detail as to what was done. Do they normally go into that kind of detail In a carfax? Service records are all dealer and one of them is for the repair after the accident which was rear end colission. Title is still clean.
Old Jan 5, 2019 | 03:45 PM
If the dealer inputs it in the system it will go on the CARFAX. At 40k there is not much that needed to be done
Hot Brass
Sep 6, 2020 07:15 AM
John007
Jul 28, 2018 01:18 AM
Nando Welan
Jan 24, 2016 09:26 PM
JohnnySasakiMGS
Apr 22, 2013 04:16 PM
