About To Give Up
Old Apr 15, 2012 | 07:05 PM
onempty's Avatar
Default About To Give Up
Ordered a Fuel Tank Pressure Sensor from Autozone(149.00+tax).According to mechanic wrong one!Returned FTPS though Autozone argued it was correct FTPS.Mechanic got a used FTPS which was wrong!Went to Firestone for scan,results was code #PO450.Same as frist scan!(from mechanic)Firestone tech says a 1996 Honda Accord 2.2 has no FTPS.Tech says it's a bad computer throwing faults.This is what my first scan mechanic said when the said my distributor needs replacing(forgot code #)I went to salvage yard & bought a computer.Which this computer is throwing PO450 codes.I'm now told to purchase a computer from Dealer to solve problems.Can the computer be reprogramed?If so where is there a reputable shop/company to do this?I see lots of places on the net,however after reading reviews most are ripoffs!
Old Apr 15, 2012 | 07:17 PM
See this link regarding testing the fuel tank pressure sensor:
P0453 what does this troble mean for a honda accord 1996? - JustAnswer
Old Apr 15, 2012 | 08:09 PM
Search the web a bit. The code starts with the letter P and has four numbers, so your code is P0450, not PO450.
I don't see that code in my list for the 96 accord. You may want to try checking for codes the OBD1 way. See the link for checking codes in the common diy thread on top of the gen tech help forum.
Old Apr 15, 2012 | 09:27 PM
UhOh's Avatar
If you're going to pay for mechanical service, next time go to the Honda dealer ...
Old Apr 16, 2012 | 11:43 PM
onempty's Avatar
Thanks for your help & the link.This also tells me the 1996 2.2 has a FTPS!
Old May 28, 2012 | 10:18 PM
onempty's Avatar
I broke down & went to the dealer.After a hit & miss they concluded their is no ftps on the 1996 Accord.The computer needs to be replaced.What a bomber!
Old May 29, 2012 | 06:35 PM
Have you looked at bone yards or car-part dot com for a used one, then you can do it yourself.....
badxdawgx818
Apr 11, 2007 01:37 PM
Dec 23, 2006 12:19 AM
lax1089
Dec 8, 2006 12:22 PM
rickydelcid
Aug 23, 2006 10:38 PM
