Ac Problem
Old Aug 16, 2009 | 07:51 PM
tqriddle
Default Ac Problem
Hello,
I have a 2003 Accord ex 4 cyl, automatic trans with the dual climate control with navigation.
The climate control works for the most part on both sides, however the ac does not blow on the driver side. The ac is ice cold on the passenger side, but nothing cold on the driver side. I would guess there is a 15 degree or more difference in temperature when both sides are set to the coldest setting. This temperature balancing problem only seems to be a problem regarding ac, otherwise the temperature is spot on for both sides. This is the same for every position i.e. Defrost, floor, front. Has anyone ran into this? how big of an issue is this?
Old Aug 17, 2009 | 08:25 AM
I've heard of this happening when it's low on refrigerant. Don't just add refrigerant; have it checked by measuring both low & high side pressures.
Old Aug 19, 2009 | 11:27 PM
tqriddle
Thanks Jim,
Im havn't had that looked at yet, but one I do I will let you know if it fixes the problem. The kind people told me that the reason it was not working on the driver side is because of the excessive ducting on the driver side...right
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
