Accord 3.0l Transmission Help...
Old May 18, 2019 | 04:04 PM
robw13's Avatar
Question Accord 3.0l Transmission Help...
Ok, my Transmission Stopped shifting this week and will only run in 1 gear. No Reverse and D1-4 run the same. Code P1751 & Flashing D4 which I know points towards the Solenoids but could the transmission be going out?
Also, The fluid on the Stick Looks and Smells ok. Didn't know if a Drain & Fill with newer solenoids would correct the issue. Also, I drove it around the block earlier in all Gears & All gears are the same, cleared code and comes back almost immediately even when parked. No changed in gears except in P D4 or N.
Any help much appreciated
2000 Accord
3.0l V6
Auto Trans
195K
Old May 18, 2019 | 08:18 PM
shipo's Avatar
This is the type of issue which is virtually impossible to diagnose over the internet. The fact is, the 4-Speed unit in your car is not known for longevity, and with 195,000 miles on it, there probably isn't much life left in the tranny.
desiredkarma
Nov 9, 2015 03:13 PM
MessAround
Aug 13, 2011 09:45 AM
mamtsberg
Mar 17, 2010 09:15 PM
sidebee
Feb 24, 2007 10:06 PM
HondaDad
Jan 29, 2007 01:02 AM
