Accord 3.0l Transmission Help...
Ok, my Transmission Stopped shifting this week and will only run in 1 gear. No Reverse and D1-4 run the same. Code P1751 & Flashing D4 which I know points towards the Solenoids but could the transmission be going out?
Also, The fluid on the Stick Looks and Smells ok. Didn't know if a Drain & Fill with newer solenoids would correct the issue. Also, I drove it around the block earlier in all Gears & All gears are the same, cleared code and comes back almost immediately even when parked. No changed in gears except in P D4 or N.
Any help much appreciated
2000 Accord
3.0l V6
Auto Trans
195K
2000 Accord
3.0l V6
Auto Trans
195K
This is the type of issue which is virtually impossible to diagnose over the internet. The fact is, the 4-Speed unit in your car is not known for longevity, and with 195,000 miles on it, there probably isn't much life left in the tranny.
MessAround
Aug 13, 2011 09:45 AM
