Accord runs rough when cold put OK when warmed up
Old Nov 14, 2010 | 11:39 AM
Here's a video, which also explains about measuring resistance when cold:
http://www.youtube.com/watch?v=uRcgdo4tfFo
A slow reacting coolant temperature sensor may possibly cause problems too.
Old Nov 14, 2010 | 12:02 PM
Coolant temp, intake air temp, O2 sensor are all monitored by engine computer which can be accessed w/ an OBD2 scanner. If you know someone w/ a scanner that will monitor system sensors, this may allow you to check several things at one time.
The OBD2 scanner will also report fuel trim which may also indicate a problem. Most of the key components will set a CEL when things are not w/i specification. So your problem is something slightly off, but not enough to set CeL. This makes for a difficult problem to resolve.
Malcontent
Aug 4, 2014 02:43 PM
lilmammaszoo
Jun 21, 2012 08:40 PM
chris30721
Jan 6, 2011 08:06 AM
Accord Pete
Jan 31, 2010 02:50 PM
Joegonz
Oct 10, 2009 11:01 PM
