accord v6 tachometer gone crazy
Old May 5, 2006 | 01:06 AM
gfavro@msn.com
Default accord v6 tachometer gone crazy
Honda Accord 1995, V6 with 120,000 miles. Tachometer goes crazy 0 to 1500 and all over the place. If I turn the engine off and let it rest for a while it corrects the problem and then starts jumping all over the place.
What do I do to correct the problem?
Could this be an ignition coil problem?
Where do I start?
Old May 5, 2006 | 11:49 AM
deserthonda's Avatar
Default RE: accord v6 tachometer gone crazy
why don't you start by telling us the year ...
Hi Des!
Yo Angelo how goes ??
Old May 5, 2006 | 03:09 PM
gfavro@msn.com
The year is 1995, Accord V6
Old May 5, 2006 | 03:10 PM
gfavro@msn.com
The year is 1995 with 120,345 miles.
Old May 5, 2006 | 07:58 PM
on the rt rear of engine comp by the shock tower there is a black plug 2 wires going to it,,( blue wires ) that's for the tach test plug , hook up a manual tach to it and see what the rpm do,,,,,,,,,,,,if they flactuate the problem is from there to ,,,,coil, ignitor,wiring . chk for possible loose connections, ., ......If rpm hold good,, the problem is from there to..... gauge, wiring ..
try and post results..
Tony1M
Aug 9, 2008 09:32 PM
Troy1988
Jul 3, 2008 06:26 PM
powerpeecee
Jun 6, 2008 07:17 PM
e777
Dec 14, 2007 04:17 PM
echolsautosales
Mar 16, 2006 11:07 AM
