Accord will not start.
Old Jul 12, 2010 | 09:28 AM
  #21
deserthonda's Avatar
try something..........................remove the plugs, clean them, crank the engine ( with key as if try to start car ) with no plugs in it for a few turns,,,,,,,,,,,reinstall plugs ,, give that a shot
Old Jul 12, 2010 | 08:09 PM
  #22
At the risk of getting shot (sorry again). Please double check the timing? I know it has nothing to do with the valve cover gasket change, they get old and things happen. You have spark?, you have gas?, you have air?....the only "other" thing that keeps the internal combustion engine from running is "those" things at the wrong time or wrong proportions.
Old Jul 12, 2010 | 10:48 PM
  #23
kris_loehr's Avatar
If when you say the plugs have carbon they have a dull black coating then you have a rich mixture, and as I suggested and now deserthonda pull the plugs and crank it over to get the excess fuel out of the cylinders and I would install new plugs even if yours are new. With Fuel fouled plugs even if they clean up in my experience are done. Is there any chance something happened to the engine temp sensor for the computer? I believe on your Accord it is located below the distributor. I ask about that sensor as the only time I have seen a car go to full rich mixture was when that sensor was failed, but it wasn’t a Honda.
I believe poorman212 is referring to cam timing.
Old Jul 12, 2010 | 11:54 PM
  #24
Prozon's Avatar
ANY solution to my problem would be nice. I mean, it can be something other than the valve cover I just thought that would be a good area to start.
The plugs are out now. I pulled them to let things dry out a little. I'll crank it a bit before I put them back in though.
It is possible that the engine temp sensor went bad, but is there a way to check it or do I just have to replace it?
Old Jul 13, 2010 | 12:58 AM
  #25
kris_loehr's Avatar
You may want to find out if you have any codes stored
Old Oct 10, 2010 | 10:41 PM
  #26
Prozon's Avatar
Following up to the thread.
No there were no codes. I did all the suggestions.
Replaced the distributor, spark plugs, spark plug wires, distributor cap, rotor, and coil.
It runs now. Not sure which of them it was.. but changing them all seemed to do it lol.
Old Oct 10, 2010 | 10:56 PM
  #27
I hope your happy now...I know you must be because ...Problem solved .
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
OldFox
Dec 27, 2005 05:51 PM
