Air Con not working
Old Sep 10, 2013 | 09:43 AM
shony's Avatar
Default Air Con not working
Hi all........the air con on my Accord Coupe recently stopped working. I couldn't hear the clutch engaging so I assumed this was the problem. However, I also noticed the condenser fan wasn't working. Could the failed fan be the problem or is the fan not working because the clutch isn't engaging (or visa versa)
Hope this doesn't sound too confusing!!
Shony
Old Sep 10, 2013 | 11:45 AM
It could even be something else, like low refrigerant-charge, causing both. There are pressure switches in the system to prevent the compressor from destroying itself if the refrigerant has leaked out.
Should we try to guess which year/model? Is it an Accord of some kind?
Old Sep 10, 2013 | 12:06 PM
Hi Shony..what we need is what Jim asked you so your answer can be correct..
By the Way! Welcome to the HAF.
Old Sep 10, 2013 | 12:24 PM
shony's Avatar
Thanks guys............its a 1999 2.0 ES coupe and the system has a full load of gas
Shony
Old Sep 10, 2013 | 12:38 PM
shony's Avatar
Thanks guys...........its a 1999 2.0 ES coupe and the system has a full load of gas
Shony
Old Sep 10, 2013 | 03:14 PM
If you're sure the system has adequate refrigerant charge, then there are two primary fault possibilities:
1) an electrical fault to compressor circuit; compressor relay, hi/lo pressure switch open, faulty AC switch, or failed ac thermostat.
2) compressor clutch gap is too large preventing clutch from engaging (magnetic field too weak).
Suggest pulling electrical connector to compressor (single wire) and checking for 12V when compressor should be engaged (keyswitch on, AC switch on, blower on).
If you see 12V, the clutch gap must be adjusted by removing clutch plate and shim from beneath clutch plate to restore gap to spec (0.35-0.6 mm). It should be possible to do this w/o discharging system, but not an easy job.
If you don't see 12V, the electrical fault as in 1) above must be determined.
Old Sep 11, 2013 | 04:00 AM
shony's Avatar
Thanks chap.......will try what you suggest and report back
Shony
iaind
Jul 30, 2010 09:24 AM
kellysa111
Jul 12, 2009 06:10 PM
bruffy
Nov 17, 2008 02:35 PM
spliffy
Jul 29, 2008 05:31 PM
ckebottle
Apr 18, 2007 11:41 PM
