Airbag issue
Old Nov 15, 2015 | 07:14 PM
bigblock67's Avatar
Thanks for that. I will search again.
The yellow cable harness connector that plugs into the upper right-hand corner of the under-dash fuse box is not the Memory Erase Signal (MES) connector.
The MES connector is separately located behind the driver side kick panel.
Old Nov 16, 2015 | 10:28 AM
bigblock67's Avatar
I did locate MES port and did procedure. After the 2 blinks SRS light came on. Shut ign off for 15 seconds and stays on. What would next step be? Thanks
Old Nov 16, 2015 | 10:30 AM
bigblock67's Avatar
Other than going to Honda
Old Nov 16, 2015 | 02:37 PM
You can jump the 2P blue SCS connector (located under the passenger glove box area) to retrieve any SRS codes by the blinking SRS indicator on the dash.
However, the SRS unit probably needs to be replaced. You previously indicated the salvage yard may have one.
Old Nov 16, 2015 | 03:04 PM
bigblock67's Avatar
yard may have one.
The car was missing SRS when purchased. The now SRS unit came from same car that airbag came from at the salvage yard
Thank you for staying we me on this
Old Nov 22, 2015 | 05:46 AM
bigblock67's Avatar
All is cured. Pass air bag was replaced with a 3 prong instead of 2 connector. Once correct connection was made all is good. Thank you all for great advice
Old Nov 22, 2015 | 10:38 AM
  #17
A good ending....thanks for letting us know what/how it turned out.
Blueconnect
Oct 6, 2013 11:22 AM
swade730
Jul 9, 2011 02:07 PM
toicy4ya
Aug 10, 2008 02:39 PM
adbraz
Jul 6, 2005 02:37 PM
planemaker
May 15, 2005 09:40 PM
