Alarm and Lock Issue
Old May 10, 2023 | 12:36 AM
dutd33's Avatar
Default Alarm and Lock Issue
So we have a 2006 Accord V6 where the key cylinder lock on the driver’s side door is likely worn out a sped needs replacing. Problem is that the key fob no longer works and the door was opened with the alarm armed.
We disconnected the battery because we couldn’t disarm the alarm and left it overnight. When we connect the battery again the alarm keeps on going.
Any ideas on how to fix? Should we pull the alarm and immobilized fuses?
Old May 10, 2023 | 06:49 AM
Per the shop manual, unlocking with the key will disable the panic/alarm system. Can you get the key to turn in the lock to unlock? Try spraying wd-40 (or equivalent) into the cylinder to free it up.
If the fob and key won't work, you may need a scanner to reset the system.
Old May 10, 2023 | 09:37 AM
dutd33's Avatar
So unfortunately the key won’t turn so we can’t disarm the alarm that way.
lecompte51
Jul 3, 2013 01:38 AM
SissyB
Jan 10, 2013 09:32 PM
Kawickrice
Jul 15, 2012 05:57 PM
Outdoorstom
Feb 8, 2012 07:49 PM
ram2miller
Jul 21, 2008 05:25 AM
