Another clicking issue...
Old Oct 23, 2007 | 11:45 PM
apathy
Default RE: Another clicking issue...
ORIGINAL: PAhonda
Since your ABS light came on, you should check for error codes on the ABS, ECU, and TCU. Go to this link: http://www.dhost.info/accordinfo/howto/cel.html and follow the instructions.
The check engine light and D4 light should blink codes that are one number. A long blink =10, short =1. The ABS gives codes that are one number then a sub-number. Like 1-2, 1-3, etc. You might have to turn the key to the II position a couple of times to read all of the codes from the different lights.
Post the codes on here and we can help pinpoint the problem.
Oh interesting, i will have to do this or ask my friend because he said he has some sort of reader thing that tells you what is the problem. My CEL is also on but i have been ignoring it ;[
Old Oct 24, 2007 | 12:55 AM
The 96 accords can have their ECU read with a code reader, but I'm not sure that it can read the TCU or ABS control unit.
Shorting that service connector takes about two minutes to do and is pretty simple. The codes stored will definitely help determine what is causing your problem.
Old Oct 24, 2007 | 02:39 AM
2POINTautO's Avatar
ORIGINAL: falkore24
Sounds to me like a coil problem (but further diagnostics are needed to be certain). V-4's are only on motorcycles. As mentioned, Honda's use either a V-6 or an inline 4. Both the 4 and the 6 can have VTEC.
Then you have not seen my plans for a van with 5 offset motor cycles (partial) in the back for the drive train. One complete bike will pull out the rear and will be fully functional. 20 cylinders, 700 HP stock.
Old Oct 24, 2007 | 09:18 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: PAhonda
This is correct, you cannot read the ABS codes with the code reader. However, please DO read the code for the check engine light and post the number here (example P0123) so we can tell you what the code means. Those code readers have their own explanations, but often they are wrong for Hondas.
You still need to short the service connector and count the binks for the ABS code though.
Cateastrophe
Feb 8, 2013 06:56 AM
AJAX
Nov 9, 2011 11:44 AM
billyg
Oct 23, 2011 04:45 PM
HondaAccordKid
Oct 28, 2010 11:32 AM
silver03
Dec 27, 2007 07:31 PM
