another noob question. radio help
Old Jun 27, 2012 | 02:32 PM
birdman01's Avatar
Default another noob question. radio help
my radio and a/c screen doesnt light up and from what iv read around that its a factory defect? but i have no warrenty..... is there anyway to get a low cost or free replacment or should i buy a whole new head unit
Old Jun 27, 2012 | 03:36 PM
What model is your Accord, 4 or 6 cylinder, LX, EX, etc?
Edit: also, 2-doors or 4-doors?
Old Jun 27, 2012 | 04:48 PM
birdman01's Avatar
its a coupe, 2.4l i vtec and idk if its a lx or ex? it has all black leather interior, sun roof, all steering wheel controls?
Old Jun 27, 2012 | 05:01 PM
Your Accord most likely is an EX-L.
This Technical Service Bulletin (TSB) is an old one that was superseded. Honda use to sell replacement printed circuit boards (pcb) for the fix. Different trim models had different pcb part numbers. I just checked and Honda no longer sells the boards. An aftermarket seller use to have them too; but, that was several years ago and I can't find it listed anymore. (I included the old TSB for informational purposes only.)
www.driveaccord.net/forums/attachment.php?attachmentid=7096&d=1170385997
The superseded TSB only refers to replacement of the whole audio unit.
This other thread is if your unit is a similar type and have a no display problem, and you want to try to repair it yourself. But, do so at your own risk.
No Display Radio Fix - Drive Accord Honda Forums
Old Jun 27, 2012 | 06:10 PM
birdman01's Avatar
Hate to e a bother but should I just get a aftermarket stereo? If so how much would it be for the head unit and installation you think?
Old Jun 27, 2012 | 06:20 PM
It's not a bother. You can replace it with an aftermarket head unit. You will also need the aftermarket dash kit.
I really don't know the costs, as it can vary. I haven't installed an aftermarket unit in quite some time. Check out Crutchfield.com for some information and pictures, they sell everything you need and provide installation instructions. Usually, Crutchfield gives you the stereo wiring harness for no extra charge to plug into your factory harness. But, you can buy from other sellers too.
Old Nov 23, 2012 | 02:56 PM
bucknaz's Avatar
birdman01, I had the same issue and it was a $10 fix. Not sure if this is a day late and a dollar short but I thought I'd share.
https://www.hondaaccordforum.com/for...o-issue-49726/
iimzii85
Jun 29, 2010 09:44 AM
mrbaysick
Oct 1, 2008 04:43 AM
silver03
Dec 27, 2007 07:31 PM
BlackZ51Vett
Apr 19, 2007 10:08 AM
crazy
Feb 10, 2007 04:37 PM
