Auto trans shifting issue 92 Accord
Old Apr 29, 2015 | 11:30 AM
DMTMaine's Avatar
Default Auto trans shifting issue 92 Accord
Can the TCU be responsible for shifting issues off and on or would it be constant if the TCU were defective?
At issue 92 Accord gets stuck in 2nd gear. The light shows both D4 and what ever other gear I switch to. Sometimes it works other times not. I just replaced the upper solenoid because before if I tapped on it the trans would shift ok for awhile. Today worked fine halfway to work but then dropped into 2nd while going 60mph.
Old Apr 29, 2015 | 10:15 PM
djkurious's Avatar
What codes are you getting?
Old Apr 30, 2015 | 09:08 AM
DMTMaine's Avatar
Default TCU 92 Accord
I do not have a tool to read codes. I tried jumping the connector but did not get any lights flashing on the dash.
When I push on the brake I can hear the solenoid working in the lock out switch in the shifter.
Old Apr 30, 2015 | 09:39 AM
DMTMaine's Avatar
Question; I replaced the top most solenoid on the transmission. (This is the one that when this problem first surfaced I tapped lightly which caused it to shift properly again. After awhile that stopped working altogether). The second, or lower solenoid, I did not replace. Would this show up differently on a code than the TCU?
Old Apr 30, 2015 | 01:45 PM
It may be a bad TCU. Symptoms seem to match. See attached TSB's.
File Type: pdf
Old Apr 30, 2015 | 02:51 PM
DMTMaine's Avatar
Thanks TexasHonda. I need to uncover the TCU and look for the LED. I am not able to bring anything up on the dash when I jump the Scanner Plug.
Today, running and shifting perfectly. Go figure.
tashier
Nov 1, 2011 12:25 PM
matias_25
Oct 8, 2011 06:49 AM
donkeydawn11
Mar 30, 2010 06:33 AM
hho steve
Aug 17, 2008 11:22 PM
bmarshall
Jan 3, 2007 08:54 PM
