Automatic shifter lights
Old Jan 19, 2011 | 12:57 PM
deathraypa's Avatar
Default Automatic shifter lights
Hi All, I have a '97 accord and have a question about the automatic shifter lights next to the center cup holders. Are they suppose to light up? Mine don't and I can't remember if they are suppose to. If they are, is there a bulb or fuse that can be replaced?
Thanks
Old Jan 19, 2011 | 07:02 PM
The 94 Accord shop manual shows a single 1.4w lamp (AT Gear Position Console Light) that could be replaced. It is activated w/ the combination light switch on the steering column. You will need to remove the console to access. Unless you have a lot of other lights out, the fuse is OK.
94accordexgold
Nov 2, 2009 07:36 AM
Kamisamanou
Nov 4, 2008 10:42 AM
afghandragon45
Dec 31, 2007 07:08 PM
russewy
Dec 1, 2006 01:48 AM
Metalhead
Apr 26, 2006 10:42 PM
