axle
Old Jul 26, 2008 | 03:48 PM
logan's Avatar
Default axle
when replacing the front driver side axle does the ball joint need to be removed?
Old Jul 27, 2008 | 02:17 PM
Default RE: axle
Yes, damper fork, lower BJ, and tie-rod ball joint to allow knuckle to swing outboard over the axle shaft end.
If axle has never been removed, it may be stuck in the wheel bearing hub. Autozone has a tool (Front wheel hub bearing puller) that can be used to push the axle from the hub. You can hit the shaft end w/ a brass or plastic hammer, but not steel to avoid damage.
Old Jul 27, 2008 | 04:09 PM
logan's Avatar
Default RE: axle
will it require a front end alignment
Old Jul 27, 2008 | 05:08 PM
Default RE: axle
No need for alignment since you have not disturbed any alignment components.
Suggest purchasing a Haynes or Honda manual to assist. Check Online Manuals Diy post for possible download manual.
Old Jul 27, 2008 | 06:26 PM
Default RE: axle
AutoZones web site also has a detailed DIY site to help you get the job done right...
deserthonda
Feb 23, 2012 09:05 AM
nixalot
Jan 25, 2007 02:02 PM
Alekat
Dec 29, 2006 11:38 PM
wayneboard2
Dec 19, 2006 02:17 PM
Alekat
Oct 16, 2006 10:51 AM
