back together finally won't start
Old Mar 29, 2015 | 12:28 PM
westm's Avatar
Default back together finally won't start
Got put together and spins but won't crank up any suggestions. 99 ex timing kit and water pump, all marks lined up.
Old Mar 29, 2015 | 12:47 PM
Your thread was moved from the DIY section. Please do not post help questions in the DIY section, as we no longer use that section for such.
Old Mar 29, 2015 | 12:59 PM
I think your car still had a distributor. Get the timing marks lined up to TDC. Pull of the distributor cap and make sure the rotor is pointing to the #1 cylinder wire and not #4. If the rotor is pointed towards #4, then you likely installed the distributor key 180 degrees off. The key is offset, but it is possible to install it backwards. I have done this before.
Make sure the wires are in the proper firing order. Looking at the distributor from the passenger side of the car, the order should be 1, 3, 4, 2 going clockwise.
boarderdog05
Feb 5, 2010 10:05 AM
importedminds
23
Jul 10, 2008 08:43 AM
j_man_honda
57
Mar 6, 2008 12:39 PM
marbro
Feb 12, 2006 03:13 AM
dj.fli4rt
Nov 1, 2005 03:31 PM
