Bad Battery Weird Problems
Old Sep 1, 2012 | 06:14 PM
bigalcalbisque's Avatar
Default Bad Battery Weird Problems
3 things have been happening to my 1995 Honda Accord for the last 6 months, ever since I took my car to a California Smog Only Station.
Speedometer flickers a lot and can stay off for several minutes, at different times the engine light comes on and the green transmission light comes on and pulsates. 2 days ago my battery went totally dead, I actually new that it had been getting bad for the last year because if I didn't drive for 4 or 5 days I would have to jump it. I trickle charged it overnight and it wouldn't even turn my car over....yes thats how long it takes the obvious to hit me! put in brand new battery and have run the car about 60 miles with no issues....could the bad battery have been causing my 3 issues? One other thing when I was having the issues, if I turned the car off and then on again, there would be no issues but they would come back again in 2 to 10 miutes.
Thanks For Your Input, Al
Old Sep 1, 2012 | 07:13 PM
Low battery voltage and no charge from alternator (altenator light on?) will cause problems. If alt light is on, problems will return.
If alt light is not on, clean battery connections thoroughly to avoid future problems.
Old Sep 1, 2012 | 09:34 PM
Alternator light does not come on, now or when the battery was going bad. I don't think its a alternator problem, I just was curious if a bad battery and it was really bad would cause those other 3 issues to occur as I don't seem to have them now.
Old Sep 1, 2012 | 09:40 PM
Occasionally, the harmonic balancer rubber bushing will fail and allow the crankshaft pulley to slip. This will cause the battery to eventually fail due to lack of charge, however the charge light will not come on,...at least that was experience I had on an Acura.
If problem returns, check the harmonic balancer by marking a radial line from outside to inside across the rubber bushing. Run engine and observe whether inside and outside of radial line become misaligned. If yes, the pulley is slipping.
Low battery can cause starting problems, but does not cause other problems while running unless the voltage dips too low (no charging).
Old Sep 2, 2012 | 11:17 AM
Thank you, I will try that and keep monitoring it if that is not the issue.
Neptun3
Mar 11, 2017 09:13 AM
giulio76
Dec 29, 2012 11:16 AM
cadams8221218
Jul 15, 2011 07:24 AM
guugoo
May 30, 2011 06:44 PM
RoKnAzn
Jan 19, 2007 01:56 PM
