bad gasket?
Old Mar 17, 2010 | 10:16 PM
Ronracer's Avatar
Originally Posted by deserthonda
I agree with other members leak looks like valve cover gasket and possibly distr o-ring ..get a valve cover gasket and o-ring from the dealer it only costs about 8-11 dollars for both ,, the upper tube seals are a bit harder to replace on 94-97 than on 90-93 accords......they cost about 2-4 dollars each .......get ultra grey it is a lot cheaper than honda- bond ...
94-97 you have to basically hammer them out with a small hammer and screwdriver , 90-93, you could just pull them off with your hand or at times just fell off..
And like advised ,, be careful when you re-install the valve cover do not over tighten the acorn nuts ..
Ronracer why would you buy the whole top end gasket set??? you might never need to use that ,, could be a waste of money versus saving money ..
1st. i bought it and did a complete rebuild.(see my C27 tear down rebuild thread)
2nd.if one gasket goes its probably time to change some more. and if not it wouldnt hurt to have extra gaskets around for when something does break
3rd. i suggest anyone approaching 200xxx do a complete overhaul. it does wonders for performance and the life of you engine!
ddodge21
Sep 19, 2014 11:09 AM
giulio76
Dec 29, 2012 11:16 AM
MessAround
Sep 3, 2011 05:44 PM
Lukes95coupe
Jul 14, 2011 08:11 PM
thunder_x
Jul 9, 2007 11:57 AM
