bad shake!
Old Aug 7, 2006 | 08:03 AM
92Inspire's Avatar
Default bad shake!
ok as you all know its a 92 lx. when im braking from any speed i have a shake but at high speeds its severe. i do believe my left front rotor is warped so it could be that. i need to rebalance all my tires but that wouldnt make it so severe. also i have a clicking when i brake its very faint and i havent found the source of it but i think its coming from the left front. also, again, when i hit small bumps i hear a... clonk kinda sound. lol . i think its a tie rod or a control arm thats loose or a bushing needs to be replaced. im not sure any suggestions would help.
Old Aug 7, 2006 | 08:12 AM
YeuEmMaiMai's Avatar
Default RE: bad shake!
warped rotors are the #1 cause of that. If it was suspension related, it would do it regardles of braking or not
Old Aug 7, 2006 | 08:18 AM
92Inspire's Avatar
the suspension and shake problems are seprate. im pretty sure the shake is from the rotor. but i need some hlep with the clonk noise that i metioned. theres more than just one question in that post.
Old Aug 7, 2006 | 08:21 AM
get the shake taken care of first and then we can work on the clunk. That could be an axle or suspension part
Old Aug 8, 2006 | 12:54 AM
drummer1279's Avatar
Im willing to bet that the click/clunk you are hearing is a bad strut or strut mount, I had that problem a few months back.
Old Aug 8, 2006 | 01:47 AM
92Inspire's Avatar
thanks guys ill take care of what i can. i appreciate the help. ill let you know what it was when i fix it.
Old Aug 8, 2006 | 04:07 AM
deserthonda's Avatar
ORIGINAL: 92Inspire
is the severe shake at hwy speed as you are braking also or just driving.....
If it is just while driving , you could have bad tires, bent rims and out of balance wheels,or some badly worn frt suspension parts , and yes way out of balance wheels will shake loose the filling off your teeth
sounds like you might have more than a single issue ..
as for suggestions,, my friend you needs to inspect all the frt suspension parts,,, if any are loose replace as needed and test drive the car .. chk the tires and the wheel balance chk inner and outer tie rods, chk lower and upper ball joints,
MustangCobra
Mar 14, 2015 01:24 PM
giulio76
Dec 29, 2012 11:16 AM
ssc280
Apr 27, 2007 10:13 PM
wth71
Jun 29, 2005 03:02 PM
